โApr-17-2019 10:56 AM
โApr-18-2019 10:06 PM
Tom_M wrote:pianotuna wrote:There are different chemistries of lithium cells. The disposable AA and AAA cells use Lithium Iron Disulfide which is 1.5 volts.myredracer wrote:pianotuna wrote:You mean an internal one? Why is that and do other Li batteries like that?
redracer,
The AA li have to have a voltage dropping resistor. I'm not at all happy with them.
The nominal voltage of lithium-ion is 3.60V/cell.
There are rechargeable AA and AAA cells which have a buck converter built into each cell.
A dropping resistor will not work. Half of the energy would be wasted in heat and you would get huge voltage swings depending on the amount of current drawn.
โApr-18-2019 04:44 PM
โApr-18-2019 03:33 PM
โApr-18-2019 09:09 AM
D.E.Bishop wrote:schlep1967 wrote:X-2
Just once. Spend the money for the Energizer Ultimate Lithium Batteries. Once you see how much longer they last, you will realize they are cheaper than a dozen cheap batteries.
โApr-18-2019 08:54 AM
myredracer wrote:I guess this is called a rock and a hard place. Also, 'pay me now or pay me later.'
On Duracells, I'm danged if I'm going to get caught by the mafia prices when the batteries are right at the checkout.
โApr-18-2019 08:45 AM
โApr-18-2019 08:41 AM
D.E.Bishop wrote:A DSLR about 10 years old. The flash is really hard on the batteries. The flash is usually too strong and I can't tell if it can be dialed down. It might be time to upgrade to the latest technology and features.myredracer wrote:
Just a bit of a rant. ๐
I have an SLR camera that I use a lot, mostly for documenting restoration of 2 cars I've been working on for a while. I use ordinary AA batteries and not rechargeable ones and normally get a month or two out of them, and I use the flash often.
Put new "super heavy duty" ones in the other day. Lasted about a week for just a few pics. What the heck. I tested the old batteries with a voltmeter first before tossing them to see if one or all needed replacing and also checked the new ones which showed they were good.
Then I looked at the package. A little hard to read maybe, but it says "ideal for low drain devices". Huh?
I know there's no need to pay for overpriced Duracell or Energizer as they're pretty much all built the same way. But a week out of something labeled "super heavy duty" ain't very good.
Is the camera a SLR or a DSLR?
โApr-18-2019 08:36 AM
hypoxia wrote:OkieGene wrote:
If you are near a Costco go buy their jumbo pack of Kirkland batteries.
I quit using them after lots of leaking batteries screwing up my stuff.
โApr-18-2019 08:35 AM
โApr-18-2019 08:30 AM
โApr-18-2019 08:28 AM
โApr-18-2019 07:56 AM
โApr-18-2019 07:54 AM
myredracer wrote:hypoxia wrote:We have an LED flashlight in a holder beside the entry door that takes three D cells. Went to use it a few days ago and over the winter, the one Duracell in it had leaked while the two Panasonic ones hadn't. The batteries wouldn't have been more than 5 years old.OkieGene wrote:
So the supposedly premium ones are no better at lasting longer before leaking? Maybe alkaline batteries are like ST tires and should be routinely replaced at no more than 5 years old before they have a chance to make a mess?
โApr-18-2019 07:51 AM
โApr-18-2019 07:35 AM
