โJul-10-2018 07:27 AM
โAug-14-2018 07:03 PM
Bumpyroad wrote:Bumpyroad wrote:wnjj wrote:Bumpyroad wrote:Tom_M wrote:wnjj wrote:If it's this one:Bumpyroad wrote:
I just got from Amazon a USB male connector to a cigarette lighter female connector. $9.99. suspect it will only be 5 volts however?????????????
bumpy
It says it's 12V and can't imagine it not being so. There are devices that make 12V from 5V. It likely won't produce much current at 12V though.
https://www.amazon.com/ARECORD-Cigarette-Lighter-Socket-Converter/dp/B01J67JIOQ/ref=sr_1_3?ie=UTF8&q...
Specs say "Output:12V 0.8A Max".
that is the one but I thought those USB outlets were 5 volt?
bumpy
USB is 5V but as I said above, there are devices (IC's) that convert 5V to 12V. The IC's I work with regularly have onboard circuitry that generate +8.5V and -8.5V from a 1.2V supply.
tried it with my sirius radio.. did not work. haven't checked voltage yet.
bumpy
checked the voltage it does put out 12 volts.
bumpy
โAug-14-2018 09:49 AM
bumpy
bumpy
bumpy
โJul-25-2018 03:09 PM
bumpy
bumpy
โJul-17-2018 05:57 AM
โJul-17-2018 05:08 AM
mike-s wrote:
They had roughly the same power, it's just measured differently.
โJul-17-2018 04:21 AM
KO wrote:.
Go into a FlyingJ, Pilot or TA and look at the CB radio's for sale.
โJul-17-2018 04:05 AM
Bumpyroad wrote:No. 5 W in doesn't make 5 W out. Amplifiers are not 100% efficient, which is why the final transistors are on heat sinks.mike-s wrote:
Close. The old ones had a limit of 5 W input to the final amplifier. When they went to 40 channels, they changed that to 4 W output (AM).
that was when I thought I remembered also. so if you were in the market for a used CB, an old 23 channel would have 25% more power than a 40?
โJul-16-2018 04:04 PM
โJul-16-2018 03:46 PM
โJul-16-2018 11:18 AM
โJul-16-2018 08:45 AM
TNGW1500SE wrote:Close. The old ones had a limit of 5 W input to the final amplifier. When they went to 40 channels, they changed that to 4 W output (AM).
Older CB's were 23 channel. Then it was increased by FCC to 40 due to over-crowding. Same 4 watts either way unless illegally modified or modified and used by licensed HAM operator.
โJul-16-2018 07:34 AM
Bumpyroad wrote:TNGW1500SE wrote:
Craigslist. Search 40 channel cb radio.
actually would a 40 channel one be best? I thought that they went from 19 to 40 because of channel crowding, which is not currently an issue.
I "thought" that when the switch was made they lowered the power of the CB. My CBs haven't been "tuned" to any channel over 19 for ages, so I am wondering if wa8yxm would have a thought on this?
bumpy
โJul-16-2018 03:08 AM
โJul-15-2018 06:25 PM
