Change sat. Dish on directv
Gdlow
I take DVR from house(SWM)and use in MH (multiswitch). Looking for a quicker method of setting up. Currently the DVR has to go in and determine its not swim (or vice versa). Finally, I can get to the menu that allows me to change satellites. All in all takes about 30 minutes. Is there a way to bypass all of that and go directly to the menu?
Gary And Cathy
'05 Dolphin 5342
Honda Element following us :W
Pacnats
GS, FMCA
:C Rallys attended
FMCA Albany, Or.'06
FMCA Redmond, Or.'07
FMCA Quartzite, Az. '10...but not again:R
Good Sams "The Rally" Redmond Or. '11
FMCA Redmond August 2014
FMCA Indio, Ca 2013
7 REPLIES 7
Bill_Satellite
It's easy to change a non-SWM antenna to SWM and would likely be your best choice. "Google" Winegard SWM setup and you will find the instructions for changing a non-SWM antenna to SWM. It requires a SWM8 Switch and PI29 (not 25) power inserter and a bit of labor.
Can't we all just get along?
Bobbo
Gdlow wrote:
LittleBill wrote:
not that i have seen, might be easier to convert dish to swm using a SWM8
is that just plugging the 2 inputs from winegard into the swim then out to input one on receiver?
Yes, but with a power inserter (PI) between the receiver and the SWM8.
Bobbo and Lin
Gdlow
Gary And Cathy
'05 Dolphin 5342
Pacnats
GS, FMCA
:C Rallys attended
FMCA Albany, Or.'06
FMCA Indio, Ca 2013
Gdlow
haydoracin wrote:
Change it before you remove it from the house. Then change it in the MH before you take it back to the house.
this is the one thing I haven't tried, but will give it a whirl...Use to be that you could press some button like exit on remote that would get off the startup and let you go to menu...but doesn"t seem to exist any more.
Gary And Cathy
'05 Dolphin 5342
Pacnats
GS, FMCA
:C Rallys attended
FMCA Albany, Or.'06
FMCA Indio, Ca 2013
haydoracin
Hayden & Jan
1994 Southwind 33L P-Chassis 454
2006 Chevrolet HHR
OTY (Mini Dachsund)
Bobbo
I have a dedicated receiver for the MH. Stays set on multiswitch. Cost to buy plus $6/month. I have a D12-100.
Bobbo and Lin
LittleBill
