Continuous generator usage. How long?
ramyankee
Our kids have purchased some property southwest of us. The power is not in yet. If the deal goes through they will live in their TT. How long continuously can the genny be ran. Yes there will be monitoring and maintenance.
https://www.championpowerequipment.com/product/100230-7200-watt-dual-fuel-generator/
This is the unit they will be using.
Thanks for any info.
Rick and Patti ๐Ÿ™‚
2 Proud Christian CONSERVATIVES ๐Ÿ™‚
2002 Chevy Silverado, 8.1, Crew, LB, 3.73, 4X4
2020 Mesa Ridge 291rls
Now living in North Idaho (formerly Northeastern California) ... but the heart is with MONTANA STATE UNIVERSITY
29 REPLIES 29
time2roll
Just keep clean oil and fuel in it and let it run.
Generator is just a machine... it does not get tired, need breaks, or a nap.
theoldwizard1
Best advice is to turn it off overnight. If you don't open the refrigerator, everything will be fine for at least 8 hours.
Oil level needs to be checked at least daily.
pianotuna
Nomad III
Nomad III
Oil change every 100 hours.
Regards, Don
ramyankee
philh wrote:
If they can run on batteries, they most certainly don't need a generator that big. Don't need 7000 watt generator if you're running on 1000 watts.
Yes, they can run for a short time on batteries but with no shore power for a short time there is no way to charge.
And using ours as it is the only one available...
Rick and Patti ๐Ÿ™‚
philh
romore
Do not run it in an enclosed area! It needs fresh air and have the exhaust properly vented. To answer your question it might last 6 months under continuous usage if they are lucky, it was never designed for that. I sold and serviced portable generators, we saw a lot of them worn right out powering grow ops.
Dutch_12078
We can run our Onan onboard generator about 6 days (150 hours) between oil changes, but the longest continuous run we've done was about 4 days due to wind storm damage that took out the high voltage power lines on the road to our site.
Dutch
2001 GBM Landau 34' Class A
NRALIFR
K Charles wrote:
Page 19 says check oil every 8 hr and change oil every 50 hr if in hot weather or run hard, every 100 hr with light use.
Yup, thatโ€™s the thing about continuous usage of a small air-cooled engine driven generator. Some of them under extreme conditions you could be changing the oil every 2-3 days. My home standby generator can go 8-9 days running 24x7, and I wouldnโ€™t even want to do that very many times.
2001 Lance 1121 on a 2016 F450 โ€˜Scuse me while I whinge.
And for all you Scooby-Doo and Yosemite Sam typesโ€ฆโ€ฆโ€ฆ..Letโ€™s Go Brandon!!!
ramyankee
enblethen wrote:
I would not run it in a barn! It should be outside so it gets clean air. Could make a noise deflector using bales of cheap hay/straw.
I would shut it down, let it cool for a couple hours every day.
Why does it need to run continuously?
They will be living in it. Guessing under light use they could run on batteries for a few hours each day.
Just to add I was a tad apprehensive of a longer continued use. But it is good to get more knowledge on it...
We only used it on two occasions in northeast Cali when the power went out...
Rick and Patti ๐Ÿ™‚
enblethen
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
K_Charles
Lwiddis
Generators can ran for weeks! Noise, maintenance, necessity will limit their ranning and shorten their life. Have they considered solar?
ramyankee
It will not be located next to the TT but in a barn next them. There will be a small bit of separation. But good point.
Rick and Patti ๐Ÿ™‚
rk911
do the specs for the genny indicate anything about continuous run? if not I'd call the mfg and ask. regardless, I would shut it down at least once every 24-hrs to check oil.
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
_________________________________
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'23 Jeep Wrangler JL
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
2oldman
It will run 24/7, but they will get tired of the racket very quickly. Unless they're doing some welding, or running 3 airs, 7200 watts is way too big.
