โMar-19-2014 02:26 PM
โMar-23-2014 03:32 AM
โMar-22-2014 07:27 AM
โMar-21-2014 04:01 PM
โMar-21-2014 03:42 PM
โMar-21-2014 09:44 AM
โMar-20-2014 06:33 PM
josslund wrote:Bill.Satellite wrote:
If you want to keep working receivers at home and in the RV at the same time as you indicate you DO NOT want to setup any kind of an RV account (not sure there is such a thing either). Changing any programming while you travel will kill the Network programming at home. If you plan to travel extensively and want service in both places you may need to setup 2 separate accounts. Otherwise, one of you will need to use the OTA antenna for your Network programming if you travel too far from home.
Bill
Let me see if I can sum this all up. I can use the existing dish I have, IF I order if I order the HV24 (non DVR I believe). I want to be sure that I do not make any changes to programing while on the road if I don't want to interfere with my home programing (not a problem, as I just want it to be easy to move the receiver, no one will be using at home). If I go to far outside of my service area, I might lose local stations (I usually travel in S.W. US). Am I missing anything in this summary?
โMar-20-2014 08:21 AM
โMar-20-2014 08:11 AM
โMar-20-2014 08:10 AM
โMar-20-2014 07:25 AM
โMar-20-2014 07:22 AM
โMar-20-2014 03:08 AM
โMar-19-2014 05:37 PM
โMar-19-2014 04:58 PM
