โOct-15-2018 03:53 PM
2021 Nexus Viper 27V. Class B+
2019 Ford Ranger 4x4
โOct-16-2018 02:21 PM
โOct-16-2018 02:03 PM
charwan wrote:I'm not surprised that neither he or the order taker were concerned. Maybe they are tolerant of a difficult to enforce policy. Perhaps your son like me is a "valuable customer".
A DTV tech came to my house and installed my son's H24 receiver in my MH. If it had been wrong or he was not supoosed to, don't you think he would have said something or refused to have done it.
โOct-16-2018 02:00 PM
โOct-16-2018 01:30 PM
CA Traveler wrote:
There is a lot that DTV does not share but I'd guess that not allowing additional receivers on a Genie 2 account it technically valid. The Genie 2 supports 7 video streams and 2 can be 4K. That is a lot of bandwidth on the coax and probably 19 channel slots (7 for each 4K). Having another receiver on the coax/WiFi might just be incompatible or just not reliable.
Clearly another receiver in the RV with it's own dish does not interfere with the Genie 2. However you are now and always have been in violation of DTV policy which prohibits sharing on one account.
DTV has no way to know if you are using both the Genie 2 and RV receiver at the same time but they can disable other receivers on the Genie 2 account. So take the Genie 2 and client(s) with you in the RV.
charwan - Did you realize that using a receiver in your RV on your sons account was in violation of DTV policy?
Scenario: DTV installed the Genie 2 and clients. There were no other receivers connected. Hence cancel all of the unused receivers.
โOct-16-2018 01:24 PM
โOct-16-2018 01:15 PM
โOct-16-2018 01:01 PM
charwan wrote:
That happened to me several weeks ago. My son moved back into his home after making some repairs. Call the tech to put the receives back in and he talked him into installing the newest system in. The WIFI. Cut my receiver off in my MH after several weeks. Called to get put back they said no even though it had been working for weeks. He had to call them back out and they took the new system out and installed his old system and turned my H24 back on.
โOct-16-2018 11:15 AM
โOct-16-2018 11:13 AM
โOct-16-2018 06:30 AM
โOct-16-2018 05:22 AM
charwan wrote:msmith1199 wrote:
And Bill, you say not a big deal then you go on to explain the solution is exactly what Directv says I can't do and several other people confirm that. Directv is saying I can't have another receiver that doesn't hook to the Genie. And I want HD channels. That's the main reason I got the Winegard Traveler dish.
msmith119 It doesn't make sense what they say "DRTV". Mine worked for several weeks after my son installed the his new system "So it can work with the latest systems" it just quit when they cut his old receivers off. Someone in the "ivory tower" decided not to let you use the two systems together.
Now there is someone on here that tells he has some inside info to the fact that Directv won't cut 101 and 119 off. I read the article and it says they won't. You can go read for yourself. MOHO
โOct-16-2018 05:14 AM
RAS43 wrote:Bill.Satellite wrote:
That's really not even a big deal. OK, you have to get a new receiver (HD) but you could do that today and use the HD receiver to pick up the SD broadcast. The only important question is what programming will be available in HD from the 101 satellite. My bet is that it will be a minimal number of channels and not worth having a dome and DTV.
Bill, could you explain this a bit more.I usually take along an SD receiver to use with the SD dish. This summer I tried our bedroom HD receiver, an H25-500 and never could get it to work. Just looking for options. Thanks
โOct-15-2018 10:22 PM
โOct-15-2018 10:01 PM
โOct-15-2018 09:27 PM
