Disposing of XP Netbook
TomG2
Someone might get some good our of a working netbook, but obviously I want to remove any personal information. It has no CD/DVD drive. Is there a formatting option which will still boot up?
27 REPLIES 27
TomG2
The "crack" is hardly visible and does not limit using the Netbook. "If" it had a working operating system, it would be worth something to somebody. Thanks to all for their suggestions.
1492
Moderator
Moderator
TomG2 wrote:
Discarding a netbook with a cracked screen and no operating system makes perfectly good sense to me.
A detail that was left out of your previous posts, or I must have missed it? In which case, I would also just send it off for recycling. And would not have even taken the time to post the other info.
In the future, if concerned about your personnel info by thinking that a factory restore alone with wipe out all your data, is not the case. You should do a secure wipe first. Then do a factory restore.
Even if a factory restore includes a full format, nothing more than a quick format with a surface scan, it does not erase all your personnel data that hasn't been written over.
TomG2
Discarding a netbook with a cracked screen and no operating system makes perfectly good sense to me. If the Acer recovery had worked, I would have kept it for a spare, but I am not going to spend hours and hours trying different software to maintain a device that is not worth more than fifty dollars after five years of service.
1492
Moderator
Moderator
TomG2 wrote:
I am going to remove the hard drive and render it useless. I will probably have to pay someone to dispose of what's left of the computer. I am disappointed that the Acer restore method did not work for me.
Destroying the HD and rendering a perfectly useful Netbook, without installing a replacement drive, makes little sense? But, unfortunately, many believe in outdated or inaccurate info posted on the NET that doesn't necessarily apply to current PC systems.
All you need to do is to use a free self booting utility that securely wipes the drive. Basically, just deletes exiting files and wipes the free space. Which is what I tried to explain earlier. Or use the secure erase function built into HD/SSD firmware, which is what I do, but not as straight forward a procedure as using a separate freely available software erase utility.
If you're dead set on discarding your Netbook, you can take it to Goodwill for recycling under Dell Reconnect: Donate any brand of computer to Goodwill.
Tom_M1
Here's a link to a web page that may be helpful:
http://milescomer.com/tinyempire.com/notes/ntldrismissing.htm
If you have a USB thumbdrive click on the ntldrusb.zip link in Step 2 to download the file. Unzip the file and check the readme.txt for instructions.
If all fails, rather than destroy the drive get an external USB hard drive enclosure. You can then install the drive into that and use it for additional storage.
Tom
2005 Born Free 24RB
170ah Renogy LiFePo4 drop-in battery 400 watts solar
Towing 2016 Mini Cooper convertible on tow dolly
Minneapolis, MN
BruceMc
If you have a recycling center, often times they take electronics without charge right along with normal stuff. We've seen all manner of old electronics at our recycling center including dozens of ancient windoze computers.
2016 Forest River Sunseeker 2250SLEC Chevrolet 6.0L
TomG2
BruceMc
TomG2 wrote:
The netbook in question is a Acer Aspire One, which has a conventional hard disk drive.
I have a 32-bit XP one of those - I replaced the spinner HD with an SSD. It is much faster to boot. As a Mac user, I didn't have much need for it but certain GPS applications were windoze only. I got a good deal on it and it got used a fair amount but now it gathers dust. I've moved on to Parallels/windoze 7 on the Mac, and to new hiking GPS hardware that is more Mac compatible. Magellan and I haven't gotten along for a few years...
The HD is very easy to access - remove a screw in the cover on the bottom & pop it open. One more screw on the HD bracket and the HD comes right out. A replacement 250Gig can be had for as little as $25 these days.
TomG2
1492
Moderator
Moderator
Tom_M wrote:
Chris Bryant wrote:
Netbooks use solid state drives, which are easier to erase securely. If you can boot off a usb drive, I would use DBAN, alomg with installing Lubuntu.
Most netbooks have a standard spinning disk type hard drive. Netbooks have been pretty much replaced by tablets and ultrabooks. I suspect that a computer running Windows XP will be old enough that solid state drives were quite rare.
Not that uncommon. The DELL WIN XP Netbook I recently purchased has an SSD system drive. It also has an SDHC slot to expand additional storage space if so desired.
Chris_Bryant
MrWizard wrote:
YES..for yourself
he wants to clean it..then give it away (donate)
NOT install a new OS..somebody else might not be able to use
But it's a netbook, not a laptop, and lubuntu is easy for anyone used to XP, plus it is still supported and secure.
-- Chris Bryant
MrWizard
Moderator
Moderator
YES..for yourself
I can explain it to you.
1997 F53 Bounder 36s
Chris_Bryant
Ah- you're correct- I was thinking ultrabook... my bad.
I would still install Lubuntu on it though :).
-- Chris Bryant
