DVDs from different regions
rickjf
Has anyone had the issue of having DVDs from different regions and the player (Jensen) that's in the RV only seems to play region 1?
many of our favorite movies cannot be played except on the PC.
if anyone has any ideas, thanks
Rick & Connie
GMC duramax
Arctic fox 25P
6 REPLIES 6
1492
Moderator
Moderator
sch911 wrote:
How did you come by DVD's from other regions? Region 1 is all of North America!
I buy DVDs from around the world, so can relate to the OP's situation. If doing so, you should always check the region coding, and also if the DVD is encoded in PAL. Many DVD players available in the U.S. will also play PAL. But then again, many won't.
1492
Moderator
Moderator
Actually, I believe region coding has more to do with marketing territories than anything else. But the solution for desktop players is to get one that is region free as mentioned. The problem is going to be to find one that replaces the built-in Jensen.
Another solution may be to play them on your computer or notebook using something like the free VLC player, which will play all regions and both NTSC/PAL. Either connect directly to your LCD(?), HDMI would be the easiest, or use one of the available wireless streaming solutions.
bob_nestor
Most DVD players will "lock" into the Region of the first DVD that is played on it. Sometimes you can find firmware downloads for the DVD player that will unlock the player so it can be reset on the next DVD (which can be a pain), or permanently unlock the player for any Region.
The other option can be to rip the DVD on your PC or Mac and rewrite it as a Region free DVD or as a DVD coded to the Region recognized by your DVD player. The problem with this approach is the DVD may have additional piracy prevention encoding. There is software that can get around this, but its use in the US is legally questionable. The law is a bit murky about being able to do this on CDs/DVDs that you own; it is pretty clear you can't do it on CDs/DVDs you don't own. And to make it just a little more difficult, most US sites that host downloadable software that does things like this won't have copies. You typically have to download it from a site outside the US.
Hondavalk
Amazon.com. Type all region DVD players. There's a bunch
sch911
OEM Auto Engineer- Embedded Software Team
09 Holiday Rambler Endeavor 41SKQ Cummins ISL
2012 Jeep Grand Cherokee Limited Toad
SAR_Tracker
Sure. It's to prevent piracy. I "believe" you can get a player that will play from all regions, but don't ask me where you'd get it....
Rusty & Cheryl
2011 F250 2WD 6.2L Gasser
2008 Weekend Warrior FB2100
"Common sense is in spite of, not the result of, education" - Victor Hugo (1802-1885)
