MiFi/Verizon
Bob_Vaughn
I have the Version MiFi that is no longer active.......can I activate it with straight talk ? I got tired of paying for it and not using it......
12 REPLIES 12
pianotuna
Nomad III
Nomad III
email straight talk and ask?
Regards, Don
jcpainter
Bob Vaughn wrote:
Dutch_12078 wrote:
Did you know Verizon has a prepaid unlimited 4G data hotspot/Jetpack plan for $65/mo with autopay?
I did not use mine last year and ended up paying all that money for nothing..
On the pre-paid plan there is no contract so you can turn it on and off by the month. You can also get Verizon refill cards on eBay for CHEAP. You can find $40 cards for $25 . . . so that's a HUGE savings. There are other denominations available also.
jcpainter
Bob Vaughn wrote:
jcpainter wrote:
Bob Vaughn wrote:
MiFi Jetpack
The model number: 6620L, 7730L, AC791L, 8800L, Ellipsis, etc.
This can make a HUGE difference in compatibility and performance.
It is a 6620..
That's several generations old, but it's basic 4G so it should be compatible with most systems UNLESS they use a newer band that the older 6620 doesn't support. I believe the only 4G bands that the Verizon 6620L supports is 13 and 4.
Bob_Vaughn
Dutch_12078
Dutch
2001 GBM Landau 34' Class A
Bob_Vaughn
jcpainter wrote:
Bob Vaughn wrote:
MiFi Jetpack
It is a 6620..
Bob_Vaughn
DiskDoctr wrote:
Bob Vaughn wrote:
MiFi Jetpack
Isn't that 4G?
Did Verizon disable support for it, or did you turn it off?
Pretty sure I have one somewhere.
I dis abled it at the Verizon store
DiskDoctr
Bob Vaughn wrote:
MiFi Jetpack
Isn't that 4G?
jcpainter
Bob Vaughn wrote:
MiFi Jetpack
Bob_Vaughn
MiFi Jetpack
jcpainter
You say "the" Verizon MiFi . . . which model?
Tom_M1
Go to Straight Talk Compatibility and enter the IMEI number of your hotspot.
Tom
2005 Born Free 24RB
170ah Renogy LiFePo4 drop-in battery 400 watts solar
Towing 2016 Mini Cooper convertible on tow dolly
Minneapolis, MN
