โApr-01-2015 12:08 PM
โApr-02-2015 12:13 PM
โApr-02-2015 10:37 AM
CA Traveler wrote:
On a highway with MMs simply use them to check your mileage. And if you can drive at a constant speed for 5+ miles have the copilot use a phone etc to capture the elapsed time.
If if you are on a reasonably flat road a GPS should reasonably accurate at least I believe my Garmins are accurate.
I've found that the accuracy of my Garmins miles and arrival time to be accurate. The arrival time estimate is update on a per minute basis based on changing speed or route. Route changes also change the miles.
โApr-02-2015 09:36 AM
โApr-02-2015 07:01 AM
AH64ID wrote:GoPackGo wrote:
If you have a GPS that reads out MPH, set your vehicle speed at 60 mph as shown on the speedometer and compare to what the GPS says. The GPS should be accurate. If I remember correctly, My GPS says I'm actually going 63 at an indicated 65 on my speedometer.
I have yet to see a vehicle where the speedo and odo match, meaning if you adjust/learn your error based on the speedo the odo may be wrong.
I personally prefer to reset the 2nd trip meter and gps while stopped then clock a difference over a long easy drive. My old tires were within 0.3%, and the new ones look to be within 0.5% but I need another drove to verify them. My speedo reads close, but it doesn't read the same as the gps speed.
โApr-02-2015 02:11 AM
โApr-01-2015 07:49 PM
GoPackGo wrote:
Ok, I admit to assuming the speedo was linked to the odo. But if that's not the case, then where does the odo get it's info ?
โApr-01-2015 06:31 PM
โApr-01-2015 05:53 PM
โApr-01-2015 04:47 PM
โApr-01-2015 04:33 PM
path1 wrote:AH64ID wrote:
How much of an error are you talking about?
Being nobody else has the problem so it must be me. I'm just going to watch it more closely.
Can't believe how long of drive it turned out to be. We went from Yuma to Bakersfield, Google maps says 382 miles in 6 hours 6 min.
That's somewhat long for us as prefer 200-300 miles a day, but didn't want to overnight anywhere so we decided to drive it in one shot. LA traffic was a big delay (starring at cars in front of us). And grapevine was messed up because of something, so we went thru Lancaster and Mojave down thru Tehachapi to Bakersfield. Stopped a couple of times to eat and fuel up. All said and done the 6 hours and 6 min drive turned into little over 12 hours.
We keep a log (somewhere) of fuel and mileage, but I'm going to start keeping track of our mileage at beginning of the day to get a better feel of what is best for us. (Step one is finding the thing)
I'm glad people chimed in and got me straight on this. I thought maybe the on-line maps showed "air miles" and not actual miles on the ground travel.
โApr-01-2015 04:15 PM
โApr-01-2015 03:05 PM
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and two silly poodles.
โApr-01-2015 02:24 PM
โApr-01-2015 01:30 PM
