โNov-26-2017 03:40 PM
โJul-01-2018 08:14 AM
Bill.Satellite wrote:
You don't need to explain it, everyone has the ability to watch 2 different channels on 2 different TV's with the portable dome style antennas. The only restriction is that both channels must be being broadcast from the same satellite.
โJul-01-2018 07:11 AM
โJun-30-2018 12:19 PM
โDec-03-2017 01:35 PM
โDec-02-2017 08:59 AM
โDec-02-2017 08:07 AM
โDec-01-2017 04:14 PM
The 2nd receiver will be "stuck" watching programming coming from the same satellite selected by receiver #1 as that's the one that's going to control the movement of the antenna. The is the idea behind pointing to 72.7 as all of the programming is there except the Networks. This assumes you use your OTA TV antenna for the OTA programming which is also workable if you have your OTA TV antenna connected to your Dish receiver(s) and you are in an area where you are able to receive them.
โDec-01-2017 01:21 PM
โDec-01-2017 11:19 AM
โDec-01-2017 09:42 AM
โDec-01-2017 07:21 AM
โDec-01-2017 05:19 AM
โDec-01-2017 02:54 AM
โNov-30-2017 04:24 PM
