What TV/Sat set up should I get?
FF_PM
We are preparing to go full-time next month. We currently have Direct TV and like it, but we have no problem changing. Our rig has the stock TV, not very smart.
What would y'all suggest for a receiver and TV set up to install on the back wall of the trailer? I installed a King antenna last year. Only used it once while on vacation, but it seemed to work fine.
'06 F350 PSD
'06 Jayco Eagle 325BHS 'till 2010
'09 Jayco 25.5 RKS EAGLE SUPER-LITE 'till 2017
'15 Keystone Cougar 283RETWE
Former Marine, Former Cop, Current Firefighter
Everything I wanted to be as a kid!
1*
9 REPLIES 9
Bill_Satellite
grampachet wrote:
Without a second thought I would recommend Dish. We had dish for years but ATT convinced us to switch to direct. After 6 months of Direct we finally convinced them to let us cancel without paying the early disconnect fee of nearly $300. We had spent over 8 hours with various techs on line, on phone and in store and they could not fix their glitch. We could never connect/stream through the 2 new phones they sold us. Apple 8plus. Then Dish gave us $300 for coming back to them! We have Dish at home and the Dish tailgater in the 5wheel. We get HD and excellent service, we are back to being happy campers with Dish.
Without a 2nd thought I would recommend DTV. HOWEVER, that recommendation would be on the assumption that you use a Trav'ler or a Tripod for your antenna. DISH is "OK" with a dome if you only need 1 receiver and don't care too much about recording multiple channels but having to deal with the 2 sets of 3 satellites with DISH and no DNS option is pretty much a deal breaker for me (keeping full timing in mind).
Can't we all just get along?
philh
TV, get the largest smart TV you can fit into the space.
grampachet
2004 F-250 KIngRanch,CC,SB,SRW,4x4,V-10,3.73
2008 Montana 3000RK
ljr
edatlanta wrote:
I have seen way too many roof mounted sat receivers that won't work due to obstructions at the site, so a tripod has worked for me for the past 9 years full time. Take a look at www.tv4rv.com. This is the heavy duty tripod I use and I have never not been able to find a hole through the trees to get a good signal. The first time you set it up takes longer, but you learn how to do it quickly.
X2
I say that as a Winegard Travโ€™lr owner who, for several reasons, uses a tripod mounted dish most of the time. IMHO itโ€™s not worth the price.
Iโ€™d suggest Dish, this tripod, a decent meter and a dish with both eastern and western LNB assemblies. If you choose to go with the top-of-the line Hopper 3 DVR , things get slightly more complicated.
Larry
Bill_Satellite
Where he says sat receiver, he is actually referring to the antenna. The receiver is the box inside the RV.
edatlanta
Ed
KM4STL
2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, Prodigy Controller, B&W Companion Hitch, Progressive Industries EMS-PT50C, TST Systems 507 TPMS
2010 Jayco Designer 35RLTS,Cummins/Onan RV QG 5500 EVAP
Fulltime since 2010
FF_PM
I an in a 2015 Keystone cougar. I like the idea of keeping the service I already have. I agree the install is a bit steep
'06 F350 PSD
1*
Bill_Satellite
For full time I would recommend just using your current DTV receivers and install a Winegard Trav'ler. It's expensive ($1600 plus install) but it gives you the exact same service that you have at home (important when your RV IS your home).
Domes work but they will let you down often due to weather. Based upon your signature, I have no idea what kind of RV you have but "original" TV doesn't help much.
Johno02
Unless you absolutely have to have a lot of channels everywhere, just go with OTA Stations. Otherwise Dish seems to have the best deals and equipment for RVs. With our Sensar IV antenna, we can get stations up to 70 miles away, depending on terrain. We bought a portable satellite antenna and a Dish receiver and service on a per month account. Used it once, for about three months, haven't used it again. If we go on another long trip, I might activate it again, but not just for a weekend trip. If I had full time satellite service at home, that would be a different situation, and I would use it all the time. In your case, as a full timer, it would make sense. My opinion would be Dish.
Noel and Betty Johnson (and Harry)
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and two silly poodles.
