Is it possible to provide wi-fi covering an entire campground YES.
So what's the PROBLEM $$$$$$$$$$$$$$
That's right, money, costs lots of it.
First: Wi-Fi is designed for fairly short range,, Plus there are but 3 channels the do not overlap 1-6 and 11) if you are on 2,3,4, or 5 you overlap both 1 and 6, 7-10 six and 11 and of course in all cases "All the channels in between" and some on the other side of six may apply. (7 for example also overlaps 5).
This limits you, plus all the folks with Mi-Fi devices on assorted channels.
So to cover a park you need to put up repeaters, and/or taller towers. And this is just to get the signal to the outlying sites.
Now you have the bandwidth issue... Bandwidth costs money, The more bandwidth the more money.
This is true, I was there, One park I stay at for the first few years of Wi-Fi you had to go to the family center, now if you had a good LONG RANGE Wi-fi adapter (I DO)there were a few sites that could see "The dome" (As the center was called) but only a hand full (like 5-10) park has over 700 sites. Today most of those sites are covered by repeaters and multiple accounts.
Well the park had simply taken a Linksys home/small office router out of the box and plugged it in, they did not even change the SSID.
I'd get there 1st thing in the AM, log in, get my coffee and no tribble at all.
But others, arriving later, NO CONNECTION.. for a while I'd set 'em up by using manual I/P and telling them how to reset it to auto later. but....Not that easy to do.
Finally.. One day.. i decided to try a bit of 1st level hacking.. I typed in the default password for the router administrator and sure enough, (See took it out of the box and plugged it in) I was in.. Turns out it had a 50 account limit, that's all, 50 user IPs was all it could assign.. Changed it to 100 and that held till July 4 weekend when I was again helping people by giving them static IPs' I logged in and pulled the DCHP IP list and showed how all 100 addresses were already assigned.. I explained that in the early days it was just laptops but by then you had laptops, PDAs The park's wired comptuers of course and many cell phones.. In fact here's one Suzzies I Phone"
Turns out the woman I as assisting... Suzzie.
