โJan-24-2021 12:06 PM
โFeb-12-2021 09:56 AM
โFeb-11-2021 02:30 PM
โFeb-11-2021 01:43 PM
โJan-27-2021 04:50 AM
โJan-27-2021 03:16 AM
โJan-26-2021 04:24 PM
Bill.Satellite wrote:
Just FYI, it's never a good idea to scrape the center wire. The signal travels on the surface of the wire and you want that wire to remain as smooth as possible.
As to the other leads, yes, coax is coax. If you really have the SK-SWM3 antenna you should only have 1 wire that leads from the SWM LNB to the base. Where are these other coax cables? Any coax can be used to test if that cable is bad. Even a spare 50 footer sitting around somewhere.
โJan-26-2021 04:04 PM
dapperdan wrote:
I haven't had a chance to look. Did this cable have regular RG6 connectors on both ends?
My dish would turn completely over lake a saucer, make a complete 360 search with the lnb arm pointed straight up and then return to the stow position. Was your experience similar?
Did you get CS help from Winegard? "
Our dish operates the same as yours. I didn't notice any corrosion on either end of that short cable I replaced. To be honest the faulty cable didn't "look" bad but obviously was. I managed to be able to use my "homemade" cable for a little while but I made it a bit too short and eventually that one failed. The replacement has been working great ever since. :BDan
I didn't have the luck you had. The replacement cable made no difference. I talked to Winegard CS and I will have to pack up the turret and return it to Iowa. Repair will be a flat fee of $350. I pay shipping there and they pay return shipping. The turret weighs about 50 lbs.
As to those other connections on the base you'd have to call Winegard and ask them, I have NO idea if they'd work or not. I reconnected the replacement cable to the same terminal on the base.
Dan
โJan-26-2021 03:52 AM
mikestock wrote:
The connector at the LNB was clean as a whistle . The one at the box was a little corroded. I scrapped the center wire with a knife and Deoxed all of it. Didn't work. There are 3 coax connections in the base. Is it possible they are interchangeable? Thanks.
โJan-25-2021 05:53 PM
โJan-25-2021 09:33 AM
โJan-25-2021 08:14 AM
โJan-25-2021 07:55 AM
It is most likely the cable between the LNB and the base. It might just be the connector at the base if it got hit with a pressure washer. Remove the LNB cable and ensure it's clean and dry. If not, clean, use some dielectric grease and reinstall. If that does not fix it remove the LNB and detach the coax and run a new one. Standard coax can be used to replace the skinny coax to test the unit.
โJan-25-2021 03:17 AM
