Hydor boost brakes on a 1990 Mallard Overland
duckiee
I am having a hard time stopping my RV. The pedal goes to the floor almost. It is unsafe for me to drive. The pads, discs, rotors, etc. are all good. I found that I have hydro boost brakes. Does anyone have them and do they have trouble with them or have had any trouble? I was told that they might need to be bled?
Any info would be appreciated.
4 REPLIES 4
dakdave
hi,
this sounda to me like a problem in the master cylinder.sounds like one piston is bypassing.try to bleed system see if you get pressure at all 4 wheels.hydro boost is only an assist unit,problem here should not cause a low pedal.may cause high pedal effort or leak but not low pedal. good luck
sc3283
duckie does the pedal almost go to the floor with engine off?
hydroboost may be your problem...but you could have frozen caliper slides, soft expanding brake hoses, soft cheapy brake pads
did brakes work properly then all of a sudden begin with this problem?
If it is a class C and has sat for a while...they are known for sticking caliper slides due to water off on the frt corners of the roof
04 D-Max Crew Dually
96 Monaco Dynasty 36'
1995brave
Your rubber brake lines are probably going bad. Get then replaced and get the brake fluid replaced also.
westend
You will need to get the Mallard into a shop to inspect the brake system. Bleeding the air out of the hydraulic brake fluid may be the only thing needed but you should have it inspected. If the vehicle can't be driven, you could have a mobile tech inspect on your site or have the vehicle towed. I would not drive it.
'03 F-250 4x4 CC
