Schwintek slide out making new noise
jandkbradford
I have a Grand Design Reflection with a Schwintek system in the bed room slideout. It has stated making a new a different sound like a slapping sound. This sound staring is only when sliding out beginning about half way out. What could be causing this and should I be concerned?
Keith
7 REPLIES 7
djsamuel
mitch5252 wrote:
jandkbradford wrote:
I have greased the rails.
I am a new first time Schwintek slide owner.
Is slide maintenance supposed to be grease or that spray dry stuff with PTFE?
It is supposed to be CRC Powerlube with PTFE "only"
http://www.youtube.com/watch?v=8KbVRFMo1Rg&feature=youtu.be
2013 Camplite 21BHS Trailer, Ram 1500 Tow Vehicle
xzyHollyxyz
2015 Fun Finder 189FDS
2013 Nissan Frontier Crew Cab SV 4x4
jandkbradford
Thank you Brokentone for the reply.
Brokentone
I had a scraping noise when moving the slide. What I found was that when the hole through the frame where the actuator passes through was cut they left the oblong piece of steel inside the frame. It was able to move a little bit. I cut a piece off of it and it moved towards the rear. All seemed good till it slid forward and the noise came back. I disconnected the actuator, tied it up, tried to remove the piece. It would not come out, I clamped it to the frame and cut pieces off with a sawsall until it was small enough to remove, took about 3 hours. All is well.
Good Luck
jandkbradford
Thank you for responding.
I have been on the outside and inside. Does not appear to be a seal flap. The sound seems to originate from the motor in the upper left corner (looking from inside).
TucsonJim
Keith - Do you have anyone who can stand outside and try to pinpoint the location of the noise while the slide is being activated? My first thought is that it could be a seal slapping or dragging.
2016 Ford F350 Turbo Diesel SRW 4x4
2017 Grand Design Reflection 297RSTS
2013 Ford F350 Turbo Diesel SRW 4x4 (Destroyed by fire - 8/29/16)
2014 Grand Design Reflection 337RLS (Destroyed by fire - 8/29/16)
old_guy
sounds like a dry rail.
