Tool kit?
Raife
Good afternoon. While I have my nice set of tools at home, I am curious about getting a dedicated "tool kit" for the TT.
I didn't find any RV/TT specific tool kits and assume the required tools are all typical/common tools.
Is there anything I am missing? Anyone have a recommendation for a decent tool kit?
I was considering: Amazon Basics
I will be bringing one of my extra drills...
Not looking to spend a lot (so I know the quality will not be stellular...).
Thank you.
37 REPLIES 37
theoldwizard1
1Wheeldrive wrote:
Make sure you have a #2 square head screw driver or bit for electric screw driver. Nearly every screw on the inside and outside of your trailer is a #2 square drive.
DARN ! I need a #2 Robertson 1/4" hex bit !
1Wheeldrive wrote:
You should also have a multimeter for electrical testing.
And an old fashioned 12V incandescent test light.
theoldwizard1
I put this together several years ago. It DOES all fit in that tool box, but just barely !
Lwiddis
Change a tire in your driveway to see if you have everything. Donโ€™t fake it. Do it.
time2roll
Get a small bag. Combo driver, adjustable wrench, hammer, tape. Build as needed.
midnightsadie
roll duck tape. don,t over do it, some hose clamps. wire tye,s
Bumpyroad
Thank you.
horribly overpriced IMHO.
bumpy
Lynnmor
You should have some wrenches, check around the RV to check what sizes you might need. Be sure that you have tire changing tools that fit the spare and lugs, yes, sometimes they throw a curve ball. Add a jack that will work with the tire wasted. A drill can be used to operate stabilizer jacks, so take a look to see if that might be a real convenience for you.
1Wheeldrive
2015 GMC Sierra SLT 3500 CC Long Bed
2012 Voltage 3200
2006 KLR 650
