2010 Malibu won't crank
Orpheus1951
Our 2010 Malibu didn't turn over despite the battery being charged and no previous problems. Mechanic tested and stewed awhile, then disconnected the battery leads and held them together for a minute. Reconnecting the leads the car started right up, mechanic explaining something about capacitors needing to drain, and this problem might not happen again. Less than a week later it did. The same solution worked. Anyone with a clue about what's going on?
1 REPLY 1
Campfire_Time
It may be related to the security system. Common issue on mid-size GMs from that model generation. Two friends of ours had Impalas in that model year range and they did the same thing.
Chuck D.
โ€œAdventure is just bad planning.โ€ - Roald Amundsen
2013 Jayco X20E Hybrid
2016 Chevy Silverado Crew Cab Z71 LTZ2
2008 GMC Sierra SLE1 Crew Cab Z71 (traded)
