Base plate installers in Tucson area?
cheteckie
Bought a new toad, and need to get it equipped to tow. We use Blue Ox tow system. We want to have the work done in the Tucson area, but are having trouble finding a place to do the work. Has anyone had work like this done in Tucson at a place they can recommend?
2013 Allegro Bus
2013 Subaru WRX
4 REPLIES 4
rocmoc
All RV on Grant installed mine on our 2013 Ford C-Max and very pleased. http://www.allrvtucson.com/
Doesn't look like much but have fixed every problem I have ever had.
rocmoc n AZ/Fld/Baja
rocmoc n Great SouthWest USA
Hank85713
Camp world installed my base plates so I can recommend them. There are several small shops and mobile rv guys in the area. Also check Sandy's RV really good folks to work with, just not sure they do installs, but at the least should be able to give ya a good lead on someone. Sean and his mom run the place and are great folks.
Forget the name of the place but he is located on Dodge Blvd just north of Ajo. Small local shop was very helpful when I had questions on getting hydraulic levelers installed.
Y-Guy
Moderator
Moderator
I'm not sure if you checked but BlueOx lists the following dealers in the area, they should be able to do the work.
Quality Bumper #5
Tucson Driveline & Balance Inc.
La Mesa RV
Two Wire Fox Terriers; Sarge & Sully
2007 Winnebago Sightseer 35J
2020 Jeep Gladiator Rubicon
darbyjudy
Suggest checking at the u-haul dealers
2004 Gulf Stream 36 ft Sun Voyager triple slide
Workhorse W22 8.1
2004 Saturn VUE w/stowmaster towbar
Two Ole Pharts & One Little CocaPoo named Cuddles
