โApr-25-2019 08:00 PM
โSep-06-2019 05:41 AM
โSep-04-2019 10:36 AM
โSep-04-2019 07:46 AM
carringb wrote:downtheroad wrote:
To make hooking and unhooking the bars easier, get a ratcheting extension bar from Harbor Freight. The wrench that BlueOx supplies is worthless.
This too^
I also use the Harbor Freight ratchet breaker bar. It's far safer than the stock handle. If you have to unhook at an angle, the outside bar will still be under tension, and when it cams over any fixed handle will kick over pretty hard.
โApr-26-2019 01:48 PM
โApr-26-2019 01:13 PM
โApr-26-2019 06:34 AM
โApr-26-2019 06:31 AM
โApr-26-2019 05:34 AM
โApr-26-2019 05:00 AM
Retired JSO wrote:
I used to grease mine every 3rd long haul. Amounts to 1/2 to 1 pump on the grease gun. Wipe off the extruded grease and repeated every 3rd trip. Thatโs just me. As to bars, raise the tongue higher to relieve pressure on the bars. I also used a 20โ long pull bar with a socket and threw the CS wrench into the recycle bucket.
โApr-25-2019 08:26 PM
