I installed one on my camper last year in the dealers parking lot in about 30 minutes. They have to be one of the easiest hitches to install as there is no angle to have to mess with on the head when installing.
The main thing is you want your camper level or a little nose down. For sure not nose high while towing.
Take measurements from the ground to the top of your wheel-wells before hooking up to your trailer. Of course your rear will drop some with load. You just don't want your front of your truck to raise up.
You can add more weight distribution by reducing the number of chain links on your latch up to help bring the front down if needed.
I would suggest getting a socket and a nice breaker bar to carry with you to latch up the chains and forget the short tool they give you.
Hopefully I helped some.
James & Kim from Central Illinois
2012 Ford F250 XLT CC SB 4x4 6.7, ARE Topper and Decked Draw System
2013 Arctic Fox 25Y (1250lb tongue weight with mods)
Blue Ox Sway Pro 1500 w/Reese Titan Weight Dist Shank
