dinghy towing
timpitt
We have a 2003 Itasca Spirit 03 and a 2014 edge se what size tow dolly would we need? when storing the rv can the dolly be disconnected and be put in the storage space. Any info would be helpful we are new to dolly towing.
Thank You
timpitt
2 REPLIES 2
jdavidsmi
If we have a back in, i take the car off and place the dolly as far back into the space as possible with the tongue toward the motor home then i back in so the tongue of the dolly is under the motor home. This way there is only the tires sticking out.
or i push it up under the front, same idea.
2004 Fleetwood Terra 31H (no slides) F53 with V-10
sch911
is the Edge an AWD? If so it may not be able to be dolly towed. Check the OM under Recreational Towing for instructions on towing.
OEM Auto Engineer- Embedded Software Team
09 Holiday Rambler Endeavor 41SKQ Cummins ISL
2012 Jeep Grand Cherokee Limited Toad
