equipment needed to tow my 2007 crv
charlestown
hello I just purchased a 2007 Honda crv to tow behind my 31ft class c motor home can you please tell me what I need to buy I know I need a base plate that mounts to the frame behind the front bumper and that's all I know but im sure there is more. thanks mark
3 REPLIES 3
BarneyS
Please see the replies you received from your post on this subject in December here.
Moved to Dinghy Towing forum from Towing.
Barney
2004 Sunnybrook Titan 30FKS TT
Hensley "Arrow" 1400# hitch (Sold)
Not towing now.
Former tow vehicles were 2016 Ram 2500 CTD, 2002 Ford F250, 7.3 PSD, 1997 Ram 2500 5.9 gas engine
CA_Traveler
BTW We have towed the 04 CRV 75K miles and it's been driven 75K miles so good choice on your part. The only significant problem was last month when a front wheel bearing had to be replaced.
BE SURE you follow the CRV towing directions EVERY TIME. DW and I always check the turn signals, brake lights and pull a few feet for a check. One time the power cable wasn't completely plugged in and another time the ebrake was set. All communicated with hand held radios.
2014 Grand Cherokee Overland
Bob
CA_Traveler
You need the base plate, the tow bar, safety cables, electrical connections for the running lights and turn signals and brake lights, an auxiliary brake for the toad and a break away safety cable.
There is a wide variation of equipment and options to choose from.
Bob
