โMay-09-2017 11:07 AM
โMay-10-2017 07:34 PM
โMay-10-2017 04:08 AM
On most of the filon there is only a millimeter or so of wood remaining attached. I would like to try a chemical stripper before resorting to sanding. I might go get a heat gun after work tonight and give that a go. Any thoughts on how filon reacts to heat? Should I worry about warping it?I wouldn't use heat gun, there is a possibility of getting some bubbles with that. Acetone softens a lot of adhesives but you definitely won't like using that. Same for MEK.
โMay-10-2017 04:03 AM
DrewE wrote:westend wrote:DrewE wrote:
A piece of countertop laminate, for instance, should work just fine.
Drew, I hate to correct you since your advice is typically spot on but an owner using countertop material should make sure it is not made with paste board or MDF, the usual materials for constructed laminate counter tops. Both of those materials don't have much loading strength and there are better choices like OSB or plywood.
Please do correct me when I'm wrong! It does happen sometimes.
In this case, I was thinking of the thin sheets of the actual laminate surface that can be glued to a substrate of plywood or whatever, and not the preassembled countertop units that, as you point out, are often particle board stuff that is heavy, none too strong, and anything but waterproof. I did not very well describe that in the post, though, even though I knew exactly what I was thinking. It's funny how that works.
โMay-09-2017 09:17 PM
โMay-09-2017 08:51 PM
โMay-09-2017 08:38 PM
โMay-09-2017 08:29 PM
โMay-09-2017 08:16 PM
โMay-09-2017 08:01 PM
โMay-09-2017 06:40 PM
โMay-09-2017 01:48 PM
โMay-09-2017 01:37 PM
โMay-09-2017 11:33 AM
