โMar-15-2015 03:01 PM
โMar-24-2015 04:15 PM
โMar-15-2015 04:16 PM
โMar-15-2015 03:59 PM
โMar-15-2015 03:28 PM
โMar-15-2015 03:18 PM
Golden_HVAC wrote:
Hi,
The three female and one male ground connections are actually the tow hitch side of the wiring connection. You will need to change that connector to the 'trailer side' of the wires, so that you have 3 male and the ground will be female.
Then you can use a normal adapter that are sold at all boating supply, U-Haul, most RV supply stores, and places like E-Trailer.com. eTrailer.com
To convert your car from what is there to what you need, just buy a 6" long wire that has both connectors. Cut the wire in half, and install the side that you need using blue 'butt' connectors.
Good luck!
Fred.
โMar-15-2015 03:12 PM
Twomed wrote:
Adapter
Google knows all... ๐ ๐ Easy and no wiring required.
Porsche or Country Coach!
โMar-15-2015 03:06 PM
