Geo Tracker Towing - Help Please!
kcgaz
I have replaced my Suzuki Sidekick with a 95 Geo Tracker after it met an untimely death. When I purchased my Sidekick, I connected it to our motorhome using the flat four pole connector and everything worked perfect. When I did the same with the Tracker today, only the tail lights burned brightly, the signals do not flash. The brake and turn signals are together on the motorhome if that helps. Any assistance on figuring this out would be greatly appreciated.
3 REPLIES 3
rexlion
The mods might move this to dinghy towing for you... you might get more responses there. I wondered what you would tow with a Tracker, lol.
Mike G.
Liberty is meaningless where the right to utter one's thoughts and opinions has ceased to exist. That, of all rights, is the dread of tyrants. --Frederick Douglass
photo: Yosemite Valley view from Taft Point
WyoTraveler
A volt meter and a test light makes it easier to locate wires.
donn0128
Tail lights burn bright? Your brake lights are on. You need to rewire the connection. How? Trial and error probably is going to be your best shot.
