Help re towing on dolly
Trible_e
Anyone know if a 2013 Mercedes-Benze b250 turbo can be towed on a dolly.
It is not a 4matic. Any information will be appreciated.
Thank you
3 REPLIES 3
Bedlam
Moderator
Moderator
Everything I have read shows the automatics cannot be flat towed. If you have a manual transmission model, it can be flat towed but is not blessed by the company. I have not found any limits on FWD vehicles using a dolly, but some may be difficult if the steering locks and there is not a bypass.
If you are set on towing this vehicle, you may have to use a trailer with all four wheels up to do so without damage.
wanderingbob
Is it front wheel drive ?
gbopp
Check the owners manual. It should have the info you want.
