Honda Fit Ready Bute Elite install
Reddog15
Hello, I am looking to install a ready brute elite on my Honda Fit. Is there anyone that can provide hints or photos of the routing of the brake cable through the engine compartment? Thanks!
4 REPLIES 4
Reddog15
Thanks!
golfknut
I chose not to cut into the car's wiring and used power from the motorhome to run the lights. I had new bulbs added to the rear light housing and then four wires run to them from the plug-in socket mounted to the front of the Fit.
You can see the four wire bunch in the first photo going around the right side of the battery.
Here is a photo of one of the light housings. Hopefully you can see the original bulb and then the newly installed bulb.
2018 Newmar Canyon Star 3513
Reddog15
Thanks for the photos! Exactly what I was looking for. Another question; what system did you go with for the lights?
golfknut
Meaningful photos are hard to get......lots of things in the way.
I had a dealer do the install but here are a few photos of the setup on our 2009 Fit.
The battery w/tray needs to be removed to get good access.
Our cable goes under the battery tray. In the photo it's the silver wire shown toward the right side of the battery.
The breakaway reset switch is located just out of view toward the bottom of the photograph.
