I have had a 3 valve system and a one valve system but I have never had a two valve system. I am beginning the process of winterizing and want to bypass the hot water heater and am a little perplexed.
Cold line in on the bottom, Hot line on the top. If I shut the cold line valve it would stop water from going into the hot water tank but wouldn't it stop the water from circulating?
What are your thoughts
2017 Coleman 300tq by Dutchman Toy Hauler. 34.5 feet long and under 10k Gross. 500 watt Solar 2000 watt Inverter, 1999 Ford F250 2WD 7.3 4R100 DP Tuner, S&B Cold Air Intake, Gauges, 6.0 Trans Cooler, Air Bags.
