Installing brake for 2011 Equinox
badbob1
Looking at Invisibrake for my 2011 Equinox but no way it will fit under front seats. Where and what type of brake have others used for an Equinox? Already have a Sterling tow bar so readybrake not an option at this time. Can I mount the invisibrake under hood?
Thank You
BadBob
2 REPLIES 2
HowellJourney
We also are looking at the Chev Equinox along with the Honda CRV. After using a braking system that never knew if it worked, I plan to install the M&G Braking System. They are located about eighty miles from me but I know they have dealers across the US that install their system.
Chris & Ginny Moore Howell
Full timed from 8/30/04 to 6/1/06 in a 2002 Monaco Excutive
Will be buying a Sprinter based RV in next six months
lanerd
We have the US Gear Unified brake system that is much like your Invisibrake and on our Terrain (1st cousin to your Equinox) I install the unit under the dash board on the passenger side. Pulled back the carpet and bolted the unit to the floor pan up as high as I could get it. Ran the cable (and wires) back over to the drivers side and recovered the unit with the carpet.
Never know it's there nor can you see it.
Hope this helps
Ron
Ron & Sandie
2013 Tiffin Phaeton 42LH Cummins ISL 400hp
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified by U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Allegro
RETIRED!! How sweet it is....
