This is part of the why of ratings...the OEMs design to and test to their specifications that list the max weights at the worst conditions (ambient temps/humidty/etc, max incline going up and down, longevity, ability to manhandle that at max rating, etc, etc)
DO NOT ride the brakes going down. Get into the lowest gear comfortable for at whatever speed you wish to be at. When the speed goes above that speed...brake HARD and scrub off speed till about 10-15 MPH below that speed you wish to be at.
Then let the brake cool while it gains speed...to then brake HARD again.
Repeat till the bottom
You can also change out the diff gear ratios to a higher numberic. Don't know what you have, but going to a higher numeric diff ratio will both increase the rated GCWR and allow more engine braking in low gear.
That will eat into MPG, but IMHO, MPG is NOT of real concern vs safety/longevity/etc
-Ben
Picture of my rig1996 GMC SLT Suburban 3/4 ton K3500/7.4L/4:1/+150Kmiles orig owner...
1980 Chevy Silverado C10/long bed/"BUILT" 5.7L/3:73/1 ton helper springs/+329Kmiles, bought it from dad...
1998 Mazda B2500 (1/2 ton) pickup, 2nd owner...
Praise Dyno Brake equiped and all have "nose bleed" braking!
Previous trucks/offroaders: 40's Jeep restored in mid 60's / 69 DuneBuggy (approx +1K lb: VW pan/200hpCorvair: eng, cam, dual carb'w velocity stacks'n 18" runners, 4spd transaxle) made myself from ground up / 1970 Toyota FJ40 / 1973 K5 Blazer (2dr Tahoe, 1 ton axles front/rear, +255K miles when sold it)...
Sold the boat (looking for another): Trophy with twin 150's...
51 cylinders in household, what's yours?...
