Online sources to buy replacement parts for Travel Trailer
nesied
I hope I am in the appropriate forum. I have a 2010 Coleman travel trailer. I just noticed I have a leak around a vent in the roof. I am taking it in to have it re caulked, but I also have damage from the water to the dinette seats. (the wood is water damaged, swollen, not sure exactly how to word it). I was wondering if the wood part is something I can purchase and replace? I thought of just cutting plywood but would like everything to match and not be able to tell that I had to replace. One piece of the trim around the slide out also has damage. Any information on online sources that sell these things would be greatly appreciated.
6 REPLIES 6
DiskDoctr
GaryS1953 wrote:
Oops, should have read further. Thought you just needed to replace the roof vents.
We looked at some damaged units this Spring, so dug into it a bit.
After repairing the leak and replacing any wood, the interior materials can make a very nice, mostly unnoticeable repair, but matching them up can be a pain.
That's where a helpful RV place can be a good resource.
Use the right materials for professional results ๐Ÿ˜‰
GaryS1953
Gary in Michigan
2014 Chevy Silverado 1500 Double Cab 5.3 Liter V8
1996 Coachmen Catalina RB210 21' Fifth Wheel
495 Watts Solar, 40 AMP Renogy Tracer MPPT Controller,2 GC2 6V Batts.
GaryS1953
Amazon, Amazon, Amazon. Enough said.
Gary in Michigan
RandACampin
GOOGLE!
HEY CHECK IT OUT!! http://www.rvingoutpost.com
DiskDoctr
Water is a killer to pressed board construction campers.
Not impossible to fix, but finding matching materials...
Where are you located? Some dealers will order exact parts and even help you select them for DIY fixes.
Busdriver
Google is your friend, if anyone has the parts you need that is the best way to find them.
Busdriver
2019 2500 Chevy Duramax , - 2017 Grand Design 303 RLS
