Towing A 2014 Ford Edge FWD
novi2some
I tow a 2014 Ford Edge FWD. I use Brake Buddy brake controller. I do have the car wired to get a charge from the motor home to charge the car battery. There are times when after towing the car for 4 or 5 hours, I find the car battery dead. I use a 6-way plug on the car. There could be an issue with the split pins in the 6-way plug for the battery charge. Also, with the key in the car's ignition, the dash is still lit up. This could contribute to the drawing down of the battery. Do I need to pull the fuse for the dash, Could it be #11 fuse? What can I do to make sure I have a good connection from the motor home to the car and get rid of the split pin issue, the split pin closing up and not making a good connection.
Happy Campers Since 1980 and still kicking.
1 REPLY 1
BarneyS
Please do not post the same question in more than one forum. See any new replies to your question here.
2004 Sunnybrook Titan 30FKS TT
Hensley "Arrow" 1400# hitch (Sold)
Not towing now.
Former tow vehicles were 2016 Ram 2500 CTD, 2002 Ford F250, 7.3 PSD, 1997 Ram 2500 5.9 gas engine
