towing a GMC 1500 2015
Rhigley
How can I tow my GMC 1500 auto trans truck? What are my choices?
2016 Four Winds 31E
Amatuer Radio KF6OOK
6 REPLIES 6
acker1
I use a tranny lube pump on my 2013 Silverado. Only problem I have is my battery disconnect doesn't disconnect!!!! I've tried 4 Chevy forums and still don't have an answer. Still searching for an answer.
DICK
40' 2010 Phaeton QTH
toad--2013 GMC Sierra Crew Cab pickup 4X4
Viet Vet '65, Ia Drang Valley survivor (We Were Soldiers)
Elks
www.4ezdaz.com Same site, different URL
Rhigley
My truck is a 2014. I did a typo on the year.
2016 Four Winds 31E
mowermech
I( would normally refer you to the REMCO website, but it does not list the 2015 GMC, and does not have the 1500 listed as a 2014 model.
Therefore, I can only recommend that you read the Owners Manual under "Recreational Towing", if such a section exists.
If a driveshaft disconnect system is not available for that particular year and model, then you are quite possibly back to the trailer, or getting under it to remove the driveshaft from the differential yoke and tieing it up out of the way. I used to do that with a Datsun pickup, it isn't all THAT hard!
CM1, USN (RET)
2017 Jayco TT
sch911
Your 2WD choices are then: 1. On a trailer, or 2.Use a driveshaft disconnect system.
OEM Auto Engineer- Embedded Software Team
09 Holiday Rambler Endeavor 41SKQ Cummins ISL
2012 Jeep Grand Cherokee Limited Toad
Rhigley
2 wheel drive
2016 Four Winds 31E
sch911
Is it 4WD? If so t-case in neutral and tow it 4 down.
