โJun-09-2017 12:07 PM
โJun-09-2017 01:15 PM
โJun-09-2017 01:08 PM
DrewE wrote:
This is condensation, and it happens when the inside surface of the glass is at a lower temperature than the dew point of the air in the RV. The solutions are to either raise the temperature of the surface the air comes in contact with (i.e. insulate the glass somehow, maybe with a cover on the outside or drapery on the inside or something) or to reduce the dew point of the air in the RV (by some form of dehumidification, which may be as simple as having better air exchange to get rid of excess moisture).
Note that the furnace operation isn't really involved in the sweating, aside from it being used when the temperatures are cold outside and hence the glass gets cold. An RV furnace does not introduce moisture into the RV unless the heat exchanger is perforated; and if that's the case, it needs to be taken care of ASAP for safety's sake.
โJun-09-2017 12:57 PM
โJun-09-2017 12:41 PM
โJun-09-2017 12:37 PM
