2012 Fleetwood Southwind Roof AZ
dbrowning
I am very new to RVing and getting ready to take a trip. We have a 2012 Fleetwood Southwind Class A 35 foot. We are located in Arizona where is it very hot. I went to run my roof ac off of the generator and can't seem to find how to turn on the AC. I have the controls set on cool and set the temp to 72 with the generator running and it doesn't go on. I also checked the circuit breaker in the bathroom cabinet and it is in the on position. Is there something else, a switch somewhere to turn my roof ac on? Thanks for anyone's help on this-
Dana
3 REPLIES 3
marcsbigfoot20b
Does anything 110 volt work?
Maybe a transfer switch?
darsben
Does the thermostat have a winter/summer switch on the bottom or heat/cool?
My switch is hard to see as it is the same color as the thermostat housing and is on the bottom
Traveling with my best friend my wife!
1492
Moderator
Moderator
Moved from Forum Technical Support
