AC or generator???
MickD
I have a Duo-Therm 600 series air conditioner that runs fine on shore power but when I try to run in off the gen it kills the generator. Should I look at the AC? Like the start capacitor. Or look at the Generator?
Thanks for any help.
23 REPLIES 23
MickD
As I stated it worked fine last year.
Sfla2
that small gen will not take inrush when starting it might draw 4-5 x running amps to start
98 Coachmen "C" Santara Model FL (Front Lounge) 30.4
Ford V 10 Super Duty (same as E 450)
MickD
It was working before and with nothing on it will kill the gen. The microwave works fine and the coffee maker.
pianotuna
Nomad III
Nomad III
Hi,
Turn off all other loads--i.e. water heater, fridge and converter. See if that helps. Then add them, one at a time until you find what the genny can support.
Regards, Don
poncho62
How much power does the A/C draw in watts?
Did it work with that generator before?
A 2800 watt generator is not very big
MickD
I just checked the no load voltage with gen running and it was 114v - 118v.
Puddles
Mark Heisler wrote:
more info
name and size of generator would help
X2.. I don't know AC #'s,, how big is it? btu's would also help...
HTML
MickD
Mark Heisler wrote:
more info
Onan Microlite 2800. It has been running fine then started killing the genset.
Mark_Heisler
more info
2003 dodge 2wheel drive diesel 375hp 750torque
2007 citation fifth wheel model 29bhs
to see pictures of my truck and fifth-wheel click on view profile
