Aug-05-2019 11:17 PM
Aug-09-2019 09:46 AM
Aug-07-2019 07:13 AM
Aug-06-2019 10:19 PM
Aug-06-2019 08:29 PM
Aug-06-2019 03:51 PM
Chris Bryant wrote:
I think it’s a cheap generator not up to the task- maybe the capacitor they use for voltage regulation is getting hot and failing.
Aug-06-2019 01:50 PM
Aug-06-2019 12:56 PM
Aug-06-2019 12:37 PM
Aug-06-2019 09:06 AM
DrewE wrote:
I think possibly you have a loose or otherwise connection somewhere in your neutral line between the generator and the air conditioner, and probably between the generator and RV electric panel's neutral bus. Check that everything is good and tight. Do this sooner rather than later as a poor connection under load is a hot connection (hot as in high temperature).
Aug-06-2019 09:01 AM
MrWizard wrote:
sounds like the generator is over heating
used the oem generator compartment
did you add any fans for cooling to the compartment
are you running it with the compartment door open for extra air/cooling circulation
in the previous RV-ClassA DP, in order to use a portable generator
i installed a sliding tray/drawer
and mounted the genny on the tray
slide out to use, slide back in to store
made it easy to service, and allowed maximum fresh air cooling
Aug-06-2019 06:51 AM
Aug-06-2019 12:00 AM
