Advice for replacing ducted roof air conditioner
rob_engineer
I determined my ducted roof air unit went bad. It is a Coleman 15,000 BTU ducted unit from about 1996. Can anyone provide advice on what I need to buy to replace the bad unit? The compressor is what went bad. I assume I will buy a new top unit. I'm not sure if I need to buy anything else to complete the job. I appreciate any advice you can give. RV is 1996 Gulfstream Friendship 102 diesel class A.
1 REPLY 1
time2roll
This:
otrfun wrote:
rob_engineer wrote:
. . . I'm coming to the conclusion that my old unit is toast.
Sorry to hear your a/c may have bit the bullet ๐Ÿ˜ž
FWIW, if/when you start looking at new a/c's, recommend a close look at the Coleman Power Saver units. Chances are you can reduce your LRA and continuous current draw 25-35% vs. your current unit. Not so much a big deal when operating on commercial power, but definitely a big deal when operating on generator.
Also, there's a significant difference in performance between the NOS (new old stock) xxxxx-8xx series Coleman Power Savers and the latest xxxxxx-9xx series Coleman Power Savers. For anyone considering a Coleman Power Saver make sure you get the latest "-9xx" series.
