12 volt batteries for house battery
rfsod48
Is it possible to use 12 volt batteries for house battery? I never boondock and am looking at cost over longevity.
Roland,Linda and Matt Schwarz, LuLu, MoMo and Chewy
2005 Fleetwood Bounder 38N Catipillar C7
2015 Jeep Cherokee Latitude 4wd Drive II
Go Bucks!
11 REPLIES 11
pianotuna
Nomad II
Nomad II
Get a maintenance free 12 volt jar. It will meet your needs.
Regards, Don
tenbear
One 12v battery is all you need. The only time you will be using the battery is while you are hooking up at the campsite, or loading up at home. While hooked up at the campsite the power hookup will supply your power, while the engine is running the alternator will supply the power.
2010 Subaru Impreza Sedan
RJsfishin
God only knows why these knowitalls here would be talking 2....much less 4 6v GC batteries. Any ole 12v battery will be fine if you don't camp off grid.
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
wa8yxm
A GC-2 (Six volt) pair is around 220 Amp Hours and costs about the same as a pair of Group 24's (150 amp hours)
IF you goof and run the G-24s way down the Group XX batteris down they tend not to come back Where as I ran my GC-2s down 4 or 5 times and they came back, Lasting a total of 9 years.
I would stick with GC-2's Unless you go to something like a single Group 31 there is not much savings.. Plus There are other advantages.
I suspect if you graph cost over life.. GC-2's will be lowest cost. I know if you graph Amp Hours/Dollar they are the best but I think years/dollars will work out the same way.
MEXICOWANDERER
Eternally lugged-in that battery only does duty as a filter capacitor. Actually a starting or calcium calcium battery is the better choice. They consume less water and have less of an antimony issue, especially after several years.
time2roll
rfsod48 wrote:
No, for motor home instead of 4 6 volt batteries.
A single group 27 (12v) from Costco or Walmart is fine.
MrWizard
Moderator
Moderator
moved from technology corner
I can explain it to you.
1997 F53 Bounder 36s
pconroy328
I have one 12V car battery as the coach/house battery - so Yes you can use one or more 12V batteries. Your four 6Vs would map to two 12V batteries wired in parallel.
2oldman
Ron3rd wrote:
Not sure I understand your question; do you want to use 12v batteries for your regular stick and brick house?
Not sure.. after all, he never boondocks in his house.
One 12v battery is fine for never boondocking. 4 6v is way overkill for on-grid camping.
rfsod48
Go Bucks!
Ron3rd
Equilizer Hitch
Honda EU2000
