โApr-27-2021 07:27 AM
โMay-06-2021 07:50 AM
โMay-06-2021 06:54 AM
โMay-06-2021 06:18 AM
โApr-28-2021 01:45 PM
โApr-28-2021 11:49 AM
โApr-28-2021 10:40 AM
Timeking wrote:Keep us posted on your quest to see 14.4 volts from the WFCO.
It seems a plus of all this, is that if the battery gets a little bit discharged, and I charge it, the WFCO will likely go into bulk mode, and 14.4v is supposedly high enough to address sulfation, i.e., a little bit of time being charged at 14.4 is better for the battery than getting 13.6 all the time. Maybe. I think that at one time I had a real "smart" multi-stage converter that would hit the battery with 14.4 every so often simply for that purpose.
โApr-28-2021 09:52 AM
โApr-28-2021 06:56 AM
โApr-28-2021 06:44 AM
โApr-28-2021 05:57 AM
Gdetrailer wrote:
Op doesn't really need a battery at all if they are staying put and if that is the case the simple answer is to lose the battery.
โApr-28-2021 05:54 AM
โApr-28-2021 05:07 AM
โApr-27-2021 07:41 PM
time2roll wrote:
Yes you can turn off the battery. If you don't move you don't even need a battery. Charging the otherwise unused battery every 1 to 3 months overnight is fine.
Yes the function of the WFCO is very poor. The linked converter should go to 13.2 volts after a few days.
Timeking wrote:
Thanks. I am full-time living in the TT, and still wonder why when connected to shore power 100% of time, that it is good and/or I need to keep charging the battery. Since I am constantly using light, pump, etc., the WFCO will never go into storage mode, but will always stay in absorption mode.
โApr-27-2021 02:47 PM
โApr-27-2021 02:42 PM
pianotuna wrote:
I would get a one week timer. I'd set it to charge the battery bank 1 hour per week for each 100 amp-hours of storage. The Boondocker MBA 45 amp is an excellent choice.
