I know most of this conversation is about bulk charging, and keeping maximum amperage flowing for as long as possible to reduce generator run times, and whether AGMS are any better than flooded in this department.
While I have a battery monitor, I trust it less and less the more cycles that have accumulated either without the high amp recharge, and/or the incomplete recharge, say getting to 95% instead of 100%
Many successive 95% recharges then require a very long time for amps to taper to 0.4a at 14.7v. I've seen it take 3.5 hours to taper to 0.4 amps once 14.7v has been reached at 40 amps initial bulk current. After many PSOC cycles and low and slow solar only as the charging source, then plugging in the meanwell, I've seen it take 10 hours for amps to taper to 0.4a after it first reached 14.7v.
When many PSOC cycles have accumulated, at least on my NS AGM, the progressive capacity loss, or temporary sulfation, or whatever term one is comfortable with using, not only means that a true full 100% recharge/ recovery, not only takes longer, but amps begins tapering sooner as well. I've been quite surprised to see the battery still 35Ah from full and reaching 14.7 at only 27 amps. Usually this is more like 22 to 24AH from full when amps start tapering at 14.7v.
I imagine if one were relying on generator only, no solar, that 50 to 80%, even if 80 is not really 80% anymore, takes longer and longer to achieve, the more partial state of charge cycles that have accumulated.
I really try not to go that many cycles without either the 100%, and this usually requires alternator or meanwell contribution, which also means no less than 40 amps initially. My battery craves the high amp recharge. Ideally, in my observations, it would get 25 to 40 amps from its most depleted state, every recharge. It is not happy with low and slow solar only, and I determine this by voltage held under load for AH removed the next discharge cycle and the one after that. This behavior is predictable and repeatable.
As my battery monitor is usually at my right elbow, I check it often each recharge and discharge cycle, and likely have much more trends and tendencies data than most here. In the future, if/When I decide I require more capacity, I am torn between getting another AGM or t-1275, as I love the no amperage limitation on Northstar or Lifeline or Odyssey AGM's. I love the high CCA, the no watering, and seeing 12.7v on a 90AH battery when the screwy31 at 130Ah capacity would show 12.4v at the same level of depletion under the same loads, fills me with warm and fuzzies.
Only caveat is the AGM I will use, requires the high amp recharge after so many cycles, to remain healthy and full of grunt and would not be a good long term solar only recharge battery.
Whether the Amperage limited AGMS are more suited to solar recharges, is unknown to me, but It is incredibly obvious, how much better my AGM performs after a high amp recharge, and recent battery temperature data also makes it obvious the battery does not appear to perform better, just because it is hotter from thre high amp recharge, as the next night 24+ hours later, when the battery temperatures have returned closer to ambients, performance is still increased despite the likely low and slow to 98% having not completed the job the next day.
The time it takes amps to taper to the required level to consider an AGM 100% charged, increased with PSOC cycling and battery Age/overall cycles accumulated. In wintertime, My 200 watts of solar needs to achieve absorption voltage on my 90AH AGM by 10:30am, or there is no hope of 100% happening that day without pluggin in and letting the Meanwell finish the task.
