Air Conditioner shuts off when slide is in
sra2ssgt
I recently purchased a 2020 Jayco 287BHS. I noticed today that the A/C wouldnโ€™t come on until I put the slide room out and turned off when I put the slide back in. This is our first camper with a side slide...is this a normal feature or do I need to take it in to be looked at? I looked through my manual but didnโ€™t see any mention of a cutoff switch or anything.
2020 Jayco Jay Flight SLX 287BHS, 2011 Dodge Ram 1500
Retired Air Force 2019
11 REPLIES 11
Bumpyroad
cavie wrote:
This is the first I have heard of this problem. There is no reason for the A/C to do that unless the A/C is directly over roof when it is in and for some reason they have a interlock system installed.
same here
bumpy
dougrainer
sra2ssgt wrote:
The A/C still works...just not when the slide room is in.
The thermostat is completely accessible with the slide in.
Waiting to hear back from Jayco Customer Service.
Jayco will be hard to hear from. They are short staffed due to Covid 19. I WORK and have worked for a Jayco dealer for 26 years. You need to get the unit back to your dealer to find the cause of your problem. Doug
sra2ssgt
cougar28
Looking at the floor plan the a/c is directly about the slide when in. Also is the thermostat accessible when slide is in? Be strange for it not to be but they do strange things on rvโ€™s.
2002 F-250 SD CC 7.3PSD Auto. XLT Short Bed 4X4 Off-Rd.Pkg.Highland Green,Westin Sportsman Grille Guard (Black) RBW Li'l Rocker Slider ,Prodigy Control Towing Jayco Eagle HT 30.5 MLOK,Handy 5er tailgate
CA_Traveler
Listen to Doug. My AC A/Cs are all controlled by DC.
2014 Grand Cherokee Overland
Bob
dougrainer
NOT NORMAL. There is no reason for the slide room to have anything to do with a roof top AC unit. Slides have 12 volt wiring that is junctioned under the slide room. It is probably the wiring that is being stretched and then relaxed. Killing power to the roof AC either 12 volts or 120 volts. Did the AC work when you picked up the unit and the slide was extended? Doug
sra2ssgt
As an option it didnโ€™t seem to make sense. Guess I have a couple of phone calls to make tomorrow.
kellem
On 4th trailer and never experienced this....warranty.
cavie
2011 Keystone Sprinter 323BHS. Retired Master Electrician. Retired Building Inspector.
All Motor Homes are RV's. All RV's are not Motor Homes.
cavie
jdc1
Not normal. Mine works in or out.
