Aux Start Schematics 1997 Fleetwood F53
Danny3
Ford
Pace Arrow S
3FCMF53G4JA1325
Serial # 7775V4759248 - RV 0643-PA# 18387
I Bought this motorhome from an older couple that had it serviced locally. They were fair mechanics but their electrical was not good. The slide would not open. This is where they went south.
It was nothing more than the ground on the emergency brake.
They attached a few to many grounds and melted the wire coming from P6 and P5. My son and I wrote everything down as far as wires location goes but it has been misplaced
The schematics (Fleetwood) do not show the detail and in some places
The board I need to wire is P/N CB-115 Rev A
I need the following. Wires P7, P8, P15 attached to, Picture would help
The wires p1-4 & P1-5 that were melted I assume they are for the Aux start relay. No schematics shows this and I canโ€™t find any nomenclature on my schematics. One is black the other is yellow.
Lastly there is a blue wire attached that says Spare Aux BD. The other wire in the bundle is black with a terminal end ring type. Not sure where it goes.
I am using Fleetwood Schematic Chassis Electrical and the panel attached to the battery box. Any help would be appreciated.
3 REPLIES 3
Danny3
Thanks also to MrWizard
Danny3
To Richard Shields
I am happy to report that everything is running as it should. The Aux start is happy.
I can't thank you enough and will go out of me way to pay it forward. Those schematics did the trick.
MrWizard
Moderator
Moderator
I have a 1997 Fleetwood Bounder on the 96 F53 460
Are you talking about the Battery Control Center aka the BCC ?
Metal box with fuses and relays
On the drivers side, under the front access hatch,
Above the Battery
A picture of where you are taking about would be helpful
Use this link to upload pictures
RV Forum picture host
Simple to use,
After picture uploads, copy the location link address
And paste it in your posts here on the forum
I can explain it to you.
1997 F53 Bounder 36s
