โApr-27-2018 07:16 AM
โApr-29-2018 08:51 AM
MEXICOWANDERER wrote:
With AGM there should be near zero transfer. .15 volt difference is excessive. The high will be feeding the low to balance. When is operational stasis if that much potential is evident, grab your DMM set it for 10-amps and then find out how many milliamps are draining. Check it again an hour later. Imbalance still there?
what this "proves" is differences in chemistry. The closer the batteries pencil out the batter they will get along during the charge and discharge cycles as well as float.
โApr-28-2018 05:08 PM
โApr-28-2018 12:33 PM
โApr-28-2018 07:22 AM
โApr-27-2018 07:25 PM
โApr-27-2018 06:39 PM
MrWizard wrote:
me.. i would connect them all together
use as one bank charge at 14.4v
top charge at 14.8v
float at 13.8v
โApr-27-2018 06:09 PM
โApr-27-2018 05:21 PM
wa8yxm wrote:
I did not follow the links but as SMALL differencer in voltage during the Bulk/Absorption statges would not scare me off. The float is the same and batteries in parallel form a "power commune" each according to its ability each according to its need.
โApr-27-2018 04:55 PM
โApr-27-2018 10:52 AM
โApr-27-2018 10:35 AM
โApr-27-2018 09:47 AM
โApr-27-2018 07:40 AM
