โOct-13-2014 12:11 PM
โOct-17-2014 03:33 AM
wintersun wrote:
Harbor Freight is a place to get something that you will use once or twice and then toss and not for anything you need to be able to rely upon to work when needed.
โOct-16-2014 05:42 PM
Wayne Dohnal wrote:Not applicable at all to DC, and not applicable to 60 Hz. AC until the conductor diameter approaches 3/4 inch.
I thought that the electricity was carried on the outer surface
โOct-16-2014 09:38 AM
โOct-15-2014 11:15 PM
โOct-13-2014 04:01 PM
MrWizard wrote:
"Skin effect" As it is called is a, special situation with extremely high voltage
โOct-13-2014 02:51 PM
โOct-13-2014 01:56 PM
โOct-13-2014 01:03 PM
โOct-13-2014 12:58 PM
โOct-13-2014 12:44 PM
โOct-13-2014 12:43 PM
โOct-13-2014 12:34 PM
BFL13 wrote:
When cut, you can see their many silky thin strands instead of a few heavy copper strands, so they are very flexible. Each of the zillion thin strands is al with cu on the outside.
โOct-13-2014 12:32 PM
smkettner wrote:
These will be the last you ever buy:
http://www.genuinedealz.com/jumper-cables-booster-cable-set-1-awg-20ft
โOct-13-2014 12:30 PM
