โApr-19-2021 07:54 PM
โApr-21-2021 07:23 PM
โApr-21-2021 07:16 PM
GDS-3950BH wrote:
Wing Nuts, helping sidecutter or linesman pliers deficient thieves steal batteries since 1852.
โApr-21-2021 07:14 PM
CA Traveler wrote:swimmer_spe wrote:Your battery is compromised even if it apparently charges up. Have the battery LOAD TESTED.
OP here
So, I was going to need wing nuts for one of the batteries. Turns out it is stone dead. So, I will see if a local auto service shop can charge it as mine can't. If not,t he need for wing nuts is the least of my worries.
But regardless it's highly advisable to replace both batteries.
โApr-21-2021 07:11 PM
Fisherman wrote:swimmer_spe wrote:
OP here
If the battery is too far gone, hook it up in parallel with a good one and then hook up the charger. Some chargers need to "see" some voltage before they will begin charging.
โApr-21-2021 06:39 PM
โApr-21-2021 01:59 PM
OP here
โApr-21-2021 01:49 PM
โApr-21-2021 08:32 AM
swimmer_spe wrote:
OP here
โApr-20-2021 07:38 PM
โApr-20-2021 07:34 PM
Grit dog wrote:mobeewan wrote:
Some are 3/8 inch & some are 7/16. Carry both.
You mean 5/16.
โApr-20-2021 05:40 PM
โApr-20-2021 01:47 PM
red31 wrote:
energizer specs https://www.eastpennmanufacturing.com/wp-content/uploads/Marine-Master-Spec-Sheet-0194.pdf
โApr-20-2021 01:44 PM
wing_zealot wrote:swimmer_spe wrote:Right there is your answer, if its 1/2 inch nut/wrench it's a 5/16 inch bolt.BurbMan wrote:
Yes, most common size is 5/16-18 threads here in the US. Not sure if Canadian batteries would have metric studs?
I know it's not metric as one has studs that fit a 1/2 inch wrench.
โApr-20-2021 01:01 PM
