Best battery
Wills6_4_Hemi
I need a new battery for the fiver, I only camp with full hookups. I still would like the best longest lasting battery possible. My last Wally world battery only lasted 15 months. Suggestions please. Thanks, Will
44 REPLIES 44
agesilaus
camperdave wrote:
some people don't really want help lol.
fwiw, no way is a dual GC-2 the best bang for the buck for a pole to pole RVer.
My thought too and I have a pair of them. But a pair cost me $270. They are big and quite heavy and require more wiring and special battery boxes. Overkill for a FHU camper.
You can buy a 12V flooded cell for around $100 and AGM's for maybe $150. I'm not up to date on AGM pricing tho.
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
400W Solar with Victron controller
Superbumper
time2roll
You probably killed it. You can do that to any battery.
Do you maybe know how the battery was killed?
Otherwise the WM battery is fine.
Wills6_4_Hemi
2oldman wrote:
I think I answered correctly.
you did, thank you
Lwiddis
If your question was so simple why did you ask it?
camperdave
2004 Fleetwood Tioga 29v
2oldman
Wills6_4_Hemi
wa8yxm wrote:
Ok batteries for RV use come in A few "Flavors"
FLooded wet Cell.
On these you need to check them at least once a month (When new) and add DISTILLED water from time to time.. Once you learn how "Thirsty" they are you can stretch the time between checking up a bit but as they age they get thirstier and thirstier so stick with at least once a quarter.
The most popular battery in this class is the venerable GC-2 Golf Car battery. you need two in series to make a 12 volt battery bank (or 4,6 8 .. Even number in series/parallel).
Sealed Valve Regulated Lead Acid (Maintenance free) Most of the RV batteries in this class are MARINE/deep cycle.. **** in my not very humble opinion and I suggest against. More as to why later.
AGM.. Sub set of Sealed VRLA abobe.. now you can get these in DEEP CYCLE Which is good. but EXPENSIVE
Exotic: IE LIthium) EXPENSIVE!!!!!
Deep Cycle batteries like the Golf Car types can be run down to half full and if promptly recharged suffer normal aging only Mine lasted 9 years
Sealed VRLA MARING/deep cycle need to be kept 3/4 full or more or they suffer rapid aging.
On a Flooded wet cell. if you let 'em run dry. By By Battery. So check 'em monthly
AGM's Many brag about long life.. Tried 'em.. Not all that impressed they were the youngest batteries in the RV and the first to go. (THey were on a independent loop and properly charged)
THe other advantage of the GC-2 is that it is a very very very popular battery.. Golf courses from here to there and back again buy 'em by the small truck load.. The lines do not shut down for re-tooling nearly as often as the 12 volt lines (Re-toolign adds to the cost)
THus.. best Bang for the Buck.
thank you for staying on topic. Great info
Wills6_4_Hemi
MEXICOWANDERER wrote:
  • Is there a flooded slow recharger coupled with a temperature compensated float device?
  • Something is wrong with the OP's system
  • Even mass produced semi deep cycle marine batteries should last three years
  • He needs to educate himself as to the top three or four no no's to avoid
  • Lots of mandatory data missing
  • Describe rig
  • Converter make and specs
  • Does rig have a plug to plug into at home?
  • Does house battery charging system function OK while driving?
    Hopefully the OP will answer the above questions ๐Ÿ™‚
I'm not sure anything is missing lol, I have full hookups at home. The keystone copper canyon 5er is plugged up from time to time as all 6-8 of my previous TT and 5ers have been. I am not sure of type of converter lol. I only asked for best battery . I am 99% my system is functioning properly but I guess asking a simple question has become increasingly difficult on this forum. Some folks can't or won't simply answer the question asked. Thanks anyway.
wa8yxm
FLooded wet Cell.
MEXICOWANDERER
  • Describe rig
agesilaus
The Samsclub batteries are supposed to Exide which is said to be better than average. For what's that's worth. I think that's true east of the Mississippi. I have no idea where meadows is, Antarctica maybe?
Superbumper
BFL13
You only need a battery in the 5er when on the road.* Rule about the emergency breakaway. Get any cheap 12v battery. The Econo Power ones at Interstate dealers are refurbished and half -price.
* Except if you have an inverter/charger.
Your battery lasting time is likely from how you "maintain" it when not camping with FHU. Suggest read up on how to maintain a battery. EG read the Trojan guide on their website.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
Wills6_4_Hemi
When I checked the reviews of the battery I have many said they only lasted 12-14 months. I believe the battrry is the problem but will check the charging system.
camperdave
I'd look into why your battery died so quick. Even the cheapest **** lead battery should last longer than that if you're strictly a full hookups kind of camper.
2oldman
Best possible? Get lithium.
