โJul-13-2020 09:40 AM
โJul-13-2020 10:25 AM
jdc1 wrote:
If you're trying to get the glues ABS sections apart, in the construction trades we use a small grinder with a diamond blade. We cut the overlapping section just deep enough to touch the inserted part. Make 5-6 cuts. Then use a small (1/2") chisel to remove the overlapped ABS fitting. Sand down the lefy over particles, then start glueing the new parts in place. Be sure to use glue on both male and female parts.
โJul-13-2020 10:19 AM
โJul-13-2020 09:58 AM
gkainz wrote:schlep1967 wrote:
They can do it any number of ways. Mine has the valve right at the tank. On thing to consider is the use of a fernco coupling (google it). If he can cut right before the leak at the end of an elbow and use a fernco to attach to the new piece he should be fine.
Thanks - will look into that. My rig also has cable pull dump valves right at the tanks. I was thinking about suggesting that improvement for him, as well as combining black and grey plumbing into 1 dump valve and connector - his rig has separate dump hose connectors and separate dump valves for black and grey tanks, with the generator installed between them.
For simplicity of repairs, I think we're going to stick with just replacing the leaking parts.
โJul-13-2020 09:47 AM
โJul-13-2020 09:44 AM
