โApr-12-2022 08:18 AM
โApr-13-2022 08:42 AM
Matt_Colie wrote:
This sounds like "The truly superior pilot is the one that uses his superior judgement to preclude having to demonstrate his superior piloting skills".
If the Tesla was a hybrid, you might have a better chance. Or, you might be able to build a switching power supply to pull power from the main traction battery that I believe is 450V and about 40kWhr.
One of the great stories to me was that the Tesla Cars do have a 12v
battery that is there to power conventional systems, and if it goes down the vehicle is disabled.
Matt
โApr-13-2022 08:24 AM
โApr-13-2022 06:24 AM
JKJavelin wrote:
I'm pretty ignorant about EVs,but I would think that the number 1 concern would be draining the vehicle's battery, doing everything possible to conserve it. Why jeopardize it for the rv?
JK
โApr-13-2022 06:20 AM
valhalla360 wrote:jdc1 wrote:
It was just announced Tesla will not honor the warranty if you use it to power your house.
Sure, they just won't honor warranty for the modifications you need to do to actually make it power the house.
โApr-13-2022 06:05 AM
JK
โApr-13-2022 05:53 AM
โApr-13-2022 04:56 AM
โApr-12-2022 08:35 PM
โApr-12-2022 07:45 PM
โApr-12-2022 05:56 PM
Matt_Colie wrote:
Honest question.
I kind of hate to sound like a Luddite here, but wouldn't be cleaner, safer and easier to just carry a little gas powered generator?
You would only need to run it when things got bad.
Matt
โApr-12-2022 03:39 PM
โApr-12-2022 03:25 PM
LittleBill wrote:
throw a rock on the seat... seems complex for what could be a 2 second fix.
โApr-12-2022 02:39 PM
โApr-12-2022 01:28 PM
valhalla360 wrote:time2roll wrote:valhalla360 wrote:Easy software update if there is a calling.
Probably far fewer Tesla owners are likely to benefit on a regular basis from a similar system.
The Ford system outputs 120v AC power. I believe around 3000w peak.
To my knowledge, the Tesla can't do that with a software change. The current 7pin output being discussed is something like 7-10amps 12v DC. OK for keeping the battery up for small loads but doesn't really take advantage of the large battery bank that's available (assuming you aren't saving it for propulsion).
Doesn't mean they couldn't add an inverter at some point (physical not programing) but as mentioned, Tesla users who would significantly benefit are likely a far more rare buyer.
